Results 1 to 20 of 20
Thread: cant open downloaded .hpt or .bin files
    I cant open any file that I download that are .bin or .hpt
    it will open the editor then give me a error saying that the bin is invalid and invalid file size ???
    why??? please help!
    04 Carbon Metalic GMC SIERRA ECSB- 5.3L, 3.73 locker, loaded
    tint, dark silver metalic spray-on bedliner
    15.500 @ 86.68 -STOCK
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    what version are you using? Did this just start to happen?
    I used to be able to open them, but I ahvent tried for a while, and I went to try a few days ago, and it gave me the error.
    I am using 1.6.0
    HP Tuners Support
    (foff667)
    28,268
    you wont be able to open hpt files with 1.6...login to your customer login page & download & install 2.1.10 its a free update.
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    man..1.6 ????? you are back in the stone ages there..LOL
    -Scott -
    Yeah I know...
    so the same goes for .bin files as well?
    HP Tuners Support
    (foff667)
    28,268
    bin's you "should" be able to open with the exception of a few...post the bins you were trying to view & get your butt updated to 2.1 in the meantime mang.
    ha, just updated to the new one!
    they same to be opening now.
    one question though? is the flash updated with the scanner and editor?
    my flash is still saying 1.6 while the others say 2.1
    HP Tuners Support
    (foff667)
    28,268
    the editor is now both the editor & flasher...you shouldve uninstalled 1.6 before installing 2.1
    what do you use, write cal., write entire, etc.???
    HP Tuners Support
    (foff667)
    28,268
    okay, got it all...
    but is there a reason the read vcm takes FOREVER????
    its ALOT slower than the old 1.6
    HP Tuners Support
    (foff667)
    28,268
    what are your laptop specs? always takes me 1m45s-2m0s to read.
    its not the laptop, the specs are 2.8Ghz AMD 64bit, 1GB memory, 80GB HDD
    when it gets to reading entire VCM, its SLOOOWW
    HP Tuners Support
    (foff667)
    28,268
    is it going into slow speed mode? are you using a serial to usb connector?
    yes, i am using a serial to usb adapter...
    eventually i want the new cable that doesnt have to have the laptop in the car/truck to log
    Nov 2002
    477
    one thing to keep in mind w/files from the repository... while they all end in .bin when extracted... they are a mix of .bin and .hpt.
    When I wrote the page I didn't spend much time on the fileupload page... so all it does it take the file you want to upload, generates a random number w/a unique seed, and then calls the file that.bin (123453343.bin) , this 123453343 number is the unique key in the database and the page assumes it ends in a .bin
    Then when you download the file you go from my horist.com box (hosted here in my house) to my high speed box (transamws6.net) which is a hosted server
    Mike Horist
    00 WS6 (TA) | 04 WS6 (GTP Comp G)
    Mike \\#at&\\ horist \\&dot$\\com
    BOTH cars HP Tuners Tuned
    Apr 2005
    4,387
    wow...now I know exactly how your networks works...
    you might need to write some code to make it say .hpt on the ones that are .hpt...
    are you doing manual approval or is it getting auto approved?
    -Scott -
    Nov 2002
    477
    ^^^ manual approval ... it's a PITA right now , but I'll likely be rewriting it in the coming weeks (learning C#, so this would be a good excersize)
    the .hpt or .bin doesn't really matter though (as far as the software is concerned)..... since file extensions haven't really mattered since the windows 3.11 days lol
    Mike Horist
    Apr 2005
    4,387
    its not that it matters to the software as much..but guys with pre 2.0 are gonna want to know which ones are bins and which ones are .hpt
    -Scott -
