Results 1 to 5 of 5
Thread: Unsupported parameter
    Jun 2006
    9
    Is there any way I can get histogram number 2 working, main spark - knock retard, timing retard, when dynamic cylinder air and knock retard are unsuported parameters in the table display for 05 cobalt ss
    Have you made sure that the charts and the main table have the correct parameters inserted? For the SS/SC it should be the PID for Total Knock Retard, not the sensor name.
    2005 Stage 2 Saturn Ion Redline
    260whp, 225wtq 14.0 @ 13.7 (2nd time dragging)
    RedlineForums.com Moderator and Eager Tuning Noob.
    Chicago, IL
    Houston, TX
    349
    Most of those histograms do not pertain to the 4's, you'll have to make your own histogram.
    2.4L Twin Cam Cavalier Z24 | T3 Super 60 @ 9 PSI | FMIC | TurboXS RFL | Greddy Profec B Spec II | Custom HO Intake Manifold | 2.5" Charge Pipes | 2.5" Downpipe | HP Tuners | 5 Speed Swap | Team Green LSD | SPEC Stage 3 Clutch | Fidanza Short Shifter | Prothane Control Arm Bushings | Carbon Fiber Hood
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,303
    if you need one made post a log & exactly what you want & I'll set up 1 for you.
    Jun 2006
    9
    Got it to work, thanks for the replies
