I have a Exocet (miata) with a LE5 swap attached to a Solstice 5 speed. I'm using the E67 ecu. I bypassed the starting circuit so it turns over but will not even try to fire. When i turn the key to the on position the fuel pump primes as normal then shuts off. I'm getting 12v to the coils and to the injectors and have vats turned off. I attached pin 47 of C3 to B+ and still nothing.
I've attached my tune file if someone could take a look at this and make sure theres not something blatantly obvious I'd appreciate it!
FYI I'm a super newb to HPT but have tuned on other systems in the past.
In stand alone no B+ or ignition goes into C3. How are you controlling the powertrain relay. After key on and the pump cycles, does the pump come back on when you spin the engine (ckp test)
.Questions? pm me Steve
Ok I'll remove the power to that pin. I'm not sure what you mean by powertrain relay, the only relays I've wired that the ECU has any control over is the fuel pump and fans. And no I don't believe the pump comes back on.
The E67 is designed to run a relay to power the system. key in to ecu then out to powertrain relay. Sounds like you don't all the power wires to the ecu . Give me a call Steve 909 910 3867
Ok so apparently I did have all of those pins powered besides pin28 on J2. I had to pin out pin28 as in my print out from alldata it has the pin as not used. Anyway pinned that out and connected it to +12v and still the same thing. I'm going to go back through the program and make sure I have everything turned off.
I'm not sure if this is related or not but my harness was for an 8 pin TB and my engine came with a 6 pin TB. I bought a new connector and repinned it, if I did this wrong would there be an issue on startup?
Still having the same issues but I have verified that the CKP is indeed receiving and out putting the correct voltage. All grounds are accounted for, ECU is receiving all required B+ inputs. I don't think it matters but on J1 (C1) pin 20 function Battery positive voltage, I have connected to switched B+ instead of constant B+. Only other things I can think of ATM, I do not have any O2 sensors hooked up and the possibility of an incorrectly wired TB, also I do not have a MAF installed as I have wired in a 3.5bar Tmap.
