Results 1 to 14 of 14
Thread: another newbie. tuner says he never locks tune, look at this...
    Jun 2017
    Iowa
    61
    Dumb newbie question.
    That's not what it says at all.
    Persistence is the key to success
    Jun 2017
    Iowa
    61
    Ok, it won't read it. What is it saying?
    13,582
    Try not reading it in high speed mode. Check for power at the OBD 2 port, if you have an aftermarket radio remove the radio fuse and try reading it again.
    Jun 2017
    Iowa
    61
    Ok, I'll try reading it that way, I've run several scans just fine so I don't think power is a issue at the port, and it's the stock radio. Thank you for a real reply, I appreciate it. MM
    Jun 2017
    Iowa
    61
    Tried reading it again, failed again and got the reduced power message on the dic while it was reading.
    May 2006
    Seattle, WA
    539
    Quote Originally Posted by MarcusMilner View Post
    That's normal and fine, vehicles do weird things then you read and flash them. Dont worry and let it be, leave the key on engine off until the VCM Editor says the read is complete. Then turn it off for 15-30sec.
    Have you been able to read it successfully before?
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
    Sep 2002
    Chicago, IL
    6,397
    What version of VCM Editor are you using?
    We got this guy Not Sure, ...
    Jun 2017
    Iowa
    61
    no, just got it Friday.
    Jun 2017
    Iowa
    61
    Keith, it's 3.6, I have a ticket number, 87354. Could you look at it please?
    Jun 2017
    Iowa
    61
    I'll go out and try this, thanks, MM
    Jun 2017
    Iowa
    61
    Eric, you are the man, thank you!!! MM
    May 2006
    Seattle, WA
    539
    Glad you got it read successfully! It's a bit disconcerting the first time you read/write a vehicle, but the best action is to NOT do anything and let the software/hardware do its magic.
    Are you able to write the tune back to the controller?
    ~Erik~
    Jun 2017
    Iowa
    61
    Yes, I wrote it and saved it.
