I really need some advice here. I apologize ahead of time but I'm on a mobile device since I'm currently deployed and won't be going home for a few weeks. My dilemma is I picked up a 2011 Chevy Silverado that had a crappy bullydog tune on it and I ran into pinging and shifting issues. The tune loaded on the truck right now is located at this post labeled "DOD DELETED" https://www.hptuners.com/forum/showt...tched&p=489759
I ran the truck and it shifts amazing, and runs amamzing. Smoothest truck I've ever driven. Only problem is my 6L80 has developed a flare on part throttle shifts in the 2-3 gear. It acts fine at WOT and spirited driving, doesn't act up in manual mode, and only does it randomly. I can consistently make it flare at 2500 RPM and when it flares for the split second it does, I'll floor it to try and make it slip more but it goes into gear no issues. It's really pissing me off because I just bought the truck so I had a reliable vehicle to take home on leave. I thought buying a low mileage truck would save me some troubles but I was wrong. I'm basically looking at 4,900 to drop the trans for a rebuild or I can throw a used one in with 80,000 miles for 900 dollars. This trans is doing exactly what my 4L60 did when it exploded and left me stranded in Nebraska. (The reason I don't have that truck anymore) I've tried relearning shift adapts which just made it worse and Checking the trans fluid which is in spec. I'm at loss and am praying maybe my tune is screwed up. If I can't fix it this weekend by doing a clutch relearn or changing what you all suggest I'm dropping the grand and swapping the transmission.
Thanks everyone!
