Torque table help
I kind of understand how to set the tables and inverse, My question is when I have a whipple installed I read put the load value to 1.6 but why and where do I put my max torque on inverse I have seen 664 or do I just put there the max torque the car made? what I understand if I made 400hp at 5000 rpm at 1.1 load I go to inverse table at 516 torque and 5000 rpm, I take 400/1.1 then take that number divide by 516 and that is what goes in the inverse table. I don't understand why because I'm at 400 hp not 516 I'm latterly going from the same area so just putting max torque in that box does not help. also why do I use 1.6% load and lets say not 2.0 I would think on a turbo set up I would go higher if I have a built engine and lets say 15lbs of boost
