Results 1 to 6 of 6
Thread: VE table stuck on displaying 1 How to return to default?
    Jul 2016
    250
    I was messing with my VE table and was wondering what other ways it list the numbers (like grams, percent etc). Well I got it to the end where it just shows ones right now and I cant get it back to normal! The green option on the right side of the box(where you can enter values) just disappeared now Im stuck!
    Can anyone help? I tried uninstalling and then reinstall but it isnt working.
    Tuner jemarshall64's Avatar
    Jul 2017
    Rainier
    51
    right click, in the pop up it should give you a choice of which units you want to view it in
    99 LQ4 ---- 408
    2007 799 Heads
    BTR TRUCK STAGE III CAM 218/224 .553/.553 113+3
    .560" LIFT BTR LS6 BEEHIVE VALVE SPRINGS
    2009 NNBS Intake
    12613411 Injectors
    DBC 92mm throttle body ---- DBW 09 TB
    1999 Truck MAF Sensor
    1999 4L80E ---- 2006 4L80E
    P01 PCM ---- P59 PCM
    2020003 Operating System ---- ​12579405
    Jul 2016
    250
    Wow I feel dumb. That worked. Thank you much
    Jul 2017
    Rainier
    51
    Don't worry, you don't want to know how long it took me to find it. .
    Some tables will keep cycling through the list when you click the green symbols, some don't. No clue why the difference.
    99 LQ4 ---- 408
    2007 799 Heads
    2009 NNBS Intake
    12613411 Injectors
    Jan 2020
    New Jersey
    hey..I have the same problem ..its in my main VE table...I open it... no percent sign... I right click box and it gives me a bunch of crap but no choices to pick from...am I right clicking in the right area
    14,066
    All you have to do is the right click where all the data is. Then it will bring up a mini menu to select the units.
