I have been battling getting this vehicle (2008 escalade) to run. I have completely lost me ass on this, but I will not give up on my customers. This is my first e38 and I am not liking it. Anyways, The vehicle is completely stock with the exception of a P1SC Propcharger that makes right around 160kPa at 6k RPM. I am running custom 2-bar OS, 2 bar sensor is in and scaled in the tune, 80lb Simens Deka with correct data that I scaled for this PCM. I am doing the 50% IFR scaling, Double Stoich, and half IFR. I failed the MAF, turned off DFCO, STFT and LTFT and tuned lambda error with the wideband over the new 2-bar VE table. When he left last time it was ripping pretty good. Within a day or 2 it would heitate badly. I assumed DCFO and LTFT were doing something. He cam back and I messed with alot of things. The result to get it to rev was to add quite a bit to the Fuel-->Transient-->Impact Factor-->Gas at the higher IVT's. It seems to be operating between 300 and 340 deg F IVT. The weird thing is this FIXED IT but ONLY WHEN IN PARK revving it....once you put it in drive and start moving, it falls on its face and the STFT and LTFT's go the opposite direction. In park is adds some fuel everywhere, in drive it removes fuel. I finally populated the Inpact Factory-->Gain table to ramp it up with increasing airflow and it helped a bit...but after an hour of driving it went back to driving aweful, almost as if LTFT's were active but they are OFF! Is there any other memory that is stored besides this? I dont understand what is going on, please any help is appreciated.
Attached is the last tune file and some logs where you can see me revving it in park (0mph) and then trying to drive it (>0mph).
