i have an 01 Z06 vette, i am getting info about HPTuners, and i am wondering if this software is able to change the default setting for the traction control and active handling when you start up the car.
stock default they are both on, you can turn it off or set it to "competative mode" after starting the car. but the next time you turn on the car they will be both on again, regardless of what setting you had left it on. i am hoping that HPT will let me edit the VCM to make it go to cometative mode when the car is turned on, so i don't have to hold that damn button for 6 seconds before i can drive off. does anyone know if this is possible or not? i was unable to find the answer in the FAQ. ???
