Instaled cam on ICL, what is there to do?
Hi, guys.
I have a question about when a cam is installed in its ICL, since when compared to install it in its intake centerline, the cam is moved a few degrees, thus changing its installation of a stock cam, which is installed by aligning the points of The pinions. My question is, in the first start up, you have to do a relearning of the timing with the function of the vcm scanner so that the ecm compensate the degrees that were given to the cam? Or just what needs to be done?
