I noticed the table Flow Rate Multiplier vs. Volts for the injectors is set at 1.00 across the board in stock form.
Could you not do the classic divide the flow rate by 2 or whatever you want in order to keep the entire map under the 63.5 lb limit, and then MULTIPLY the Flow Rate Multiplier vs. Volts table by the same amount?
I'm going to try this and verify. If the end result was the same, I guess the only gain would be you don't have to touch the IVT Terms, and you would be able to see your commanded AFR in the scanner. Anything else that anyone can think of?
