all of you electrical engineers/experts can we have a discussion then an agreed upon wiring for the lc1 wb/nb. i have seen all of the viable grounding diagrams that have left me at the point of pulling out my hair and haveing a lot of wasted connectors. while some worked i would come across a reason why it shouldnt be that way. i know now that its common sense to do it the one way ive come to and that one way only. these conditions to me must be met, to me, to finalize the ground wiring:
1) ground the heater to the negative battery terminal and not the block.
2) firewall ground for the system ground and analog ground near the engines ground strap.
3) a switch/relay for the system ground for when the eio box is hooked up
4) a chassis ground for calibration wire.
5) possibly a diode between the lc1 box and eio box
it would be nice if a single wiring setup could be agreed upon and be made the standard of the setup. im sorry for the rant like nature but it has been irkking me lately. clarity means a lot to me so things are done only once and done right. thanks for reading
