Is there a way around VATS on the newer PCM's? I see the switch to turn off VATS, but I just found out that doesn't necessarily work.
Hi Eric , I have the same issue have installed 5.0 in early F100 and won't run, even though I have tried disabling VATS, would you be able to help, Thanks
Yep, PM me.
Eric Brooks
HP Tuners, LLC
I need assistance also. I'm doing a v6 to coyote swap.
PM eric
