Results 1 to 19 of 19
Thread: Exclusive 2018 Mustang GT now supported.
    Oct 2007
    Crawfordville, FL
    2,412
    2018 Mustang GT Tuning support is now available in today's beta of VCM Suite.
    Here is a read from a 2018 Mustang GT Auto for you guys to poke around in.
    Eric Brooks
    HP Tuners, LLC
    May 2016
    1,134
    Great. Thanks for the hard work. Excited to see the gains from tuning on these.
    May 2016
    1,134
    What I've wanted for a long time... Spark IAT correction based on alcohol percent. Noticed a few other cool things too but that is what stood out. That and the use of 4 knock sensors and Per Cylinder knock control from the factory.
    Tuning Addict
    6,832
    There are some interesting things in there like the fact that there are 4 different enrichment rates and wheel torque error is already raised decently over past acceptable OE levels...
    Not to change the subject Eric as I know y'all have been working around the clock, but any word on built in VVE tools or anything like that?
    Thank You Eric
    ~Greg Huggins~
    Jan 2013
    Hawaii
    2,101
    Manual control over the cams.
    a manifold charge temp sensor. I wonder if you can see that in the dash, and what kind of temps it is going to see.
    Sep 2014
    N/A
    87
    Awesome work Eric!
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    Very helpful. I am taking delivery of mine in a few months.
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Advanced Tuner yonson's Avatar
    Nov 2007
    MiSSiSSiPPi
    234
    Nice!
    May 2016
    1,134
    How many credits? Extra for TCM? Already been asked about tuning them and want a cost idea.
    Sep 2010
    872
    Very nice, just emailed support about adding beta access once more, seems it's no longer only page and I'm stuck on beta 3.7.214
    Quote Originally Posted by Jn2 View Post
    Open vcm , Click help /about and update will show available. I just added 3.7.360 today
    Sep 2010
    872
    Quote Originally Posted by GSLSE20B View Post
    just updated earlier...review th file, man that a10 has a ton of tables of off coming an on going pressure
    Oct 2007
    Crawfordville, FL
    2,412
    And I'll be adding MORE :-)
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by ridenrunwv View Post
    There is no TCM. It's all in one module. 4 credits.
    Eric Brooks
    HP Tuners, LLC
    Sep 2010
    872
    Quote Originally Posted by Eric@HPTuners View Post
    One of the things i'm waiting to see if how we will log IDC, are we logging low and high side separate I'm assuming. Also it seems there are no inferred fuel pressure tables in the fuel system tab, this has to mean the car will have actual fuel pressure sensors to monitor pressure, one for HPFP feeding the DI injectors and one for the low side feeding the PI injectors
    Correct, two measurable pressures, just like on Ecoboost vehicles.
    PI still has injector pulsewidths that can be converted to an injector DC as desired. DI has a set injection window it can inject during, so an injector DC measure changes depending on window size. I.e. 330* window, I inject for 200*, that's 60.6% INJDC, but if its a 220* window, that's 90.9% INJDC. Tuning the DI system will be the same as any other DI Ford, finding an appropriate window size maximum, and almost certainly hitting the limit of the HPFP before injectors (i.e. able to drop the high pressure before you run out of window).
    Sep 2010
    872
    Quote Originally Posted by Steven@HPTuners View Post
    Awesome, yeah, so we only have a certain window to spray fuel, that can work as out "duty cycle", but when you run out of fueling on the HPDI side we should be able to compensate using the PI injectors, that's what I'm excited to try out, If we can maintain pressure on the low side then we may be able to make big power with out needing to go with a return style fuel system on the PI side.
    I am not seeing 3.7 Beta anywhere
    Advanced Tuner AKDMB's Avatar
    Sep 2014
    NC
    344
    Quote Originally Posted by BoostedYote View Post
    Email support and request it, they will probably want your customer number too. They remove beta support pretty often now.
