Results 1 to 7 of 7
Thread: WOT question
    May 2005
    Sweden
    53
    WOT question
    I have just installed a ls6 intake and did a PCM reset, And i know it will take the car a while to relearn the fuel and timing curves, Does this include WOT. Is the PCM "learning" at WOT?
    Is it "learning" new fuel and timing for WOT?
    Pontiac Trans Am WS.7 Ram Air -98&&
    May 2004
    Wichita, KS
    157
    Re: WOT question
    I don't think there is learning going on during wot although I'm sure if there is kr that it will start sliding towards the low octane spark table.
    98 M6 TA, mods: tsp torquer(233/233 .589 112), Patriot golds, ls6 oil pump, ls6 intake, tsp lid, pacesetter LT\'s and ORY, magnaflow, fra, HPTUNER!
    May 2005
    Australia
    5
    Re: WOT question
    Quote Originally Posted by RunnWS7
    I would hope it does. How else can it learn how much fuel is needed at WOT.
    Jul 2004
    Zurich - Switzerland
    71
    Re: WOT question
    The MAF will tell the PCM how much air... more air = more fuel
    1998 convertible Trans Am
    MODS: A4 > M6 conversion, SC raptor hood, Vortech V9 G-Trim SQ, homemade water-alcohol injection
    DYNO: 410 RWHP, 417 TORQUE @ 5 PSI
    May 2005
    Sweden
    53
    Re: WOT question
    ok, thanks.
    May 2005
    Australia
    5
    Re: WOT question
    What if you are running maffles?
    Re: WOT question
    I think STFT learning is off during WoT but WoT fueling uses learnt LTFT's(+stft's ?) from the cells you pass through.
    I.e you can reach 100kpa without going WoT, so any learnings from that will be used at WoT while in the same cells.
    Aslong as your car is using STFT + LTFT's i dont see why it shouldnt be using those Learned fuelings, MAF or MAFLESS.
    Ofcourse for best results, tuning would be required.
    Ross
