What are the limits etc that need to be setup for boosted cars to not clip/code/otherwise upset the model of things? it looks like I should disable CylAir Anticipation under Airflow/General/Maf Calibration, but what about MAF Limit, CylAir WOT Multiplier, CylAir Max Mult. and next to it Desired Air Mass/Initialization, Chrono, and Max Load, or IPC/MAP Maximum?
Any other areas that need ceilings raised? If the uSec MAF reading gets near the lowest number you have to move the Default to a lower value than it correct? (Say your at 93uSec you might want to set default to 85?
Is there a way to force the thing in 100% open loop so I can log target vs actual EQ error and trim the MAF curve accurately without LTFT STFT interfering?
I noticed in this thing the MP are always 100% weighted to 14 as well?
