Results 1 to 10 of 10
Thread: Oil Starvation Parameter?
    What does this do?
    Jun 2015
    TN
    189
    I think it's a feature that cuts fuel or spark or etc, under certain conditions, like when you launch or heavy brake, or high G turn, and all the oil rushes to one direction in the pan, which could cause a momentary loss of pressure. I've never experienced this. Some tuners disable this. I left mine on
    RPS Twin Carbon Clutch
    Kook's Headers
    Ported Supercharger
    Cold Air Inductions cai
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
    Any idea what sensors are required for it to work? How it works? For example, is it via a G-meter somewhere in the car, or via the oil pressure sensor, or....? If its really to affect when oil pressure goes low, why would you ever turn it off? At the very least its telling you to do something about your oiling problem if thats the case?
    Jun 2015
    TN
    189
    I think its oil pressure. When the pickup tube goes dry for a bit
    Kook's Headers
    Ported Supercharger
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
    Aug 2014
    Western Australia
    9
    I seem to remember reading somewhere that on LS1's at least it protects engine by cutting either fuel supply or spark at idle if oil pressure under 8psi. Not sure if pressure scales upwards as rpm increases.
    Jan 2014
    Australia
    1,984
    ive only seen that enabled on the LSA tunes, mine has it disabled and im leaving it that way, i also have my low oil warning pressure increased so if anything does happen i have a early notice, waiting for it to be basicly out of oil before warning is too late
    Any more info on this? I have a customer car which is a competition drift car with an LS3 crate engine. The default setting is "disabled" however it would be nice to have this feature for a safety. The ECU is seeing oil pressure. Anybody know what parameters need to be satisfied to trigger this feature?
    Baltimore, Md
    1,208
    Quote Originally Posted by Musky@RG View Post
    Anyone?
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    Aug 2006
    Arizona
    244
    What vehicle is this ECU out of?
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Baltimore, Md
    1,208
    Most E38 have this setting
