Results 1 to 13 of 13
Thread: Need Help ASAP
    Apr 2018
    24
    Need Help ASAP
    Ok, I went to tune my truck, I read the file and saved using my last two credits. I then go to write the file and it tells me that in need to purchase a license for the file. I don't get it I already purchased the file for my truck vin. I have tried to re-read it and do it again but nope. Ive tried to uninstall HP Tuners and reinstall it and no luck I have to get this truck started today please help.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,292
    Does your vehicle use an FSCM or TCM that costs additional credits to license? That is typically the reason why it would ask you to license something upon flashing...either providing your .hpt file or a screenshot of the licensing screen would make it very simple to determine which it is.
    Apr 2018
    24
    It is an 08 Silverado that only calls for 2 credits to tune according to the vehicles list. It does have a separate tcm though.
    Apr 2018
    24
    Is there anything that can be done on your end to reset it and just retry the license procedure? Here is a copy of the tune file.
    Apr 2018
    24
    Tune File.
    Here is the Tune file not sure if you received the other one please help as soon as you can I'm in desperate need to get this truck started and tuned.
    13,589
    Are you trying to write to the FPCM while you are writing to the PCM/TCM??
    Apr 2018
    24
    It doesn't give me the option, As soon as I select write it says its an unlicensed file. Ive never had this issue tuning anything and I just need it fixed asap. Bill@hptuners anything else?
    May 2016
    Adelaide, Australia
    246
    Reread the file from the pcm, deselect fuel pump control module before reading it then you are good.
    HP Tuners Support
    (foff667)
    28,292
    https://forum.hptuners.com/showthrea...-and-licensing
    As I suspected you read the FSCM^
    Feb 2006
    South Carolina
    1,525
    Definitely read the FSCM. Just do as Ben C stated and you will be fine. When you run the read utility, choose "Gather Info" and it will display all of the available modules. Set the FSCM to "Do Not Read" and proceed as normal.
    Jaime
    Feb 2006
    South Carolina
    1,525
    It doesn't matter. As long as the file contains the read information, it will force you to license the module prior to flashing.
    Jaime
    Nov 2013
    5
    I have had nothing but read write issues since it was added I finally just added the licence and still get licence errors occasionaly
    HP Tuners Support
    (foff667)
    28,292
    Quote Originally Posted by spd2612 View Post
    Then you might consider contacting support via email.
