Hi guys, I am trying to disable DFCO to work on my injector cal, but am not having much luck.
Enable RPM is set to 7000 and disable at 6900.
Both VSS settings are 0
I even tried setting the closed throttle delay to 9s.
Still after about 1.5s of no pedal, it goes into OL TQ req. Lean. Then a couple seconds later OL inj cut. (which confusingly is still showing a 0.65ms PW, despite a 0 lb/min fuel flow rate).
I must be missing something to keep it in CL!
