Originally Posted by
MMGT1
Looks like the anti seize was applied to the entire thread of the plug, that will cause bad things to happen. If you use anti seize only apply to the top 4 or so threads. You need good contact in the lower threads as the anti seize will "insulate" the plug from the head.*Major requirement so the head can absorb the heat of the plug firing in there. Heat range does look good on the plug as it seems like its showing heat a good 5 threads up from the bottom. The "rounding" of the electrode does tell me they are done. Install a new set, anti seize only on the top few threads, and install. If you have a track nearby it is the only way to use plugs to tune the engine. You need to take a new set with you to the track, install there, pull up to start, run a pass, and pull the plugs. Then they can be properly inspected and used to see whats really going on. If at all possible, even shutting down at the end of the run, push it to the hangout area, then pull them. You will need a second set of plugs with you so you can bring your test ones home, cut the threads off of a couple and inspect where the porcelain meets the threads of the plug. Up inside there is another area that needs to be seen to use plugs as a tuning tool. If you go this route, PM me and Ill have a look at the plugs with you and give my 2 cnts on what I see.
