Page 1 of 4 1234 LastLast
Results 1 to 20 of 67
Thread: Wiring a GT500 MAP Sensor into Coyote Harness
    Senior Tuner CCS86's Avatar
    Austin
    1,089
    Does anyone know if it is possible to take an OEM GT500 MAP sensor, wire it into the factory location on a Coyote harness, then log that as a normal PID with VCM Scanner?
    Jul 2017
    529
    Being as they don't have one, I doubt it.
    Austin
    1,089
    Quote Originally Posted by MRRPMBRP View Post
    Doh, I have been misinformed.
    So, no Copperhead based engines have used a factory MAP sensor?
    I'm wondering why Ford went to such lengths to calculate MAP instead of measuring it.
    No, what I meant was to wire it into the MPVI and log that
    Jul 2017
    529
    Quote Originally Posted by C_Murph12 View Post
    This is what I did, works good, no issues, log as it's coming from the car.
    Which sensor did you use MRRPMBRP?
    Jul 2017
    529
    Just a Bosch, this one:
    https://www.bmotorsports.com/shop/pr...k5avnqcvivnep4
    Made a block of aluminum to bolt it to, then ran a vacuum hose to it, after blower to see vac/boost. Picked up a +5v power from another sensor that's on top of the motor.
    Austin
    1,089
    I don't have the pro version, so I can't log extra sensors.
    I am planning to wire a MAP to my nGauge and datalog it there.
    Thanks for the suggestion MRRPMBRP
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    I wired mine into the AC pressure sensor with a temporary adapter and logged AC pressure. Seems to work
    Austin
    1,089
    Quote Originally Posted by bbrooks98 View Post
    I wired mine into the AC pressure sensor with a temporary adapt er and logged AC pressure. Seems to work
    Nice!
    So with the nGauge, it shows a PID for MAP voltage with no reading. I guess it could just be for another late model Ford / non-Copperhead. It would be cool to find an unused circuit in the existing harness.
    Oct 2016
    Poland
    1,761
    Neat idea!
    Quote Originally Posted by CCS86 View Post
    Nice!
    Interesting - PCM has an MAP input for sure as the software suggest - you can switch the MAP on in your tune and make and log it. But which one is it?
    If you take a look at EB you can see that pin 33 is used for MAP signal voltage. And the same pin is used for AC pressure sensor in Coyote:
    Oct 2011
    Gainesville, VA
    301
    That's something i had hoped to explore and assumed existed but could never find a pinout for a map equipped car. I wonder what the EB uses for AC?
    Oct 2016
    Poland
    1,761
    Pin 52 in another connector which is Knock sensor in Coyote - I can't guarantee they are the same but this might be the way.
    Oct 2016
    Poland
    1,761
    Another way might be to use Oil Pressure sensor input . Non PP cars have 2 state oil pressure switch only and PP cars have actual oil pressure switch/transducer. I'm going to explore this way.
    Arizona
    263
    The 2013 GT500 Copperhead has a MAP sensor, so you should be able to run a MAP on a Copperhead Coyote IMO
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Jul 2017
    529
    Quote Originally Posted by STAGEUP View Post
    2014 GT500 doesn't have a MAP sensor, neither does a 2010, can't imagine a 2013 having one.
    I saw that switch, has someone actually enabled it?
    Oct 2016
    Poland
    1,761
    Nobody knows to which pin it corresponds to.
    That's correct.
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
    Austin
    1,089
    I wish I could edit the title of this thread, since it was based on bad info... but the intention is still there.
    The fact that many strategies have the [ECM] 44204 - MAP Sensor: Master enable/disable for MAP Sensor. switch; combined with the nGauge also listing a MAP Sensor Voltage as a loggable channel with a steady 0v signal, makes me think that there is a pin reserved for this.
    Does anyone have a PCM pinout / wiring diagram for the Copperhead?
    I have a MAP sensor wired in now and can log it with my nGauge, but sampling rate and limited channels make it less than ideal. I don't currently have the MPVI Pro interface, and honestly it's a pretty big expense, and more of a wiring hassle than one extra signal is worth.
