I've read 100's of posts on how to wire this thing up, and I used what was best available to me at the time for wiring and location.
I programmed the LC1 to output 3v. I checked the LC1 analog wires w/ voltage meter to confirm, and it read a range of 3-3.1v. I scan raw voltage in HPT and I get 1.382v!!!!!!
What is weird is when I first did this without forcing a volt output via LC1, I just logged raw volt output in hpt at 4.81v, and using voltmeter I read 4.95v using analog wires.
If I were to just use the PID for LC1 WB it reads approx 21.9 vs the Logworks reading of 20.9afr.
I dunno, maybe I've been fooling around too much on the TA and drained the batter too much and its throwing readings off now??
Here is my wiring scheme:
A. From the LC-1, these go to a square 4 pin stock O2 plug:
red = heater power -> NBO2 socket heater power = D
blue = heater ground -> NBO2 socket heater ground = C
yellow = analog out 1 -> NBO2 socket signal = B
green = analog ground -> NBO2 socket signal ground = A
B. Splice an extra green 6ft wire to the LC-1 green wire.
This is used in C. below.
C. From LC-1:
extra green wire -> Logger WBO2 gound
brown -> Logger WBO2 signal
black -> calibration
white -> system ground (goes to chassis ground)
Push button, goes between the black calibration wire and chassis ground where white wire is grounded. Same for anode.
