Add the new track
hi, does anyone know how to add a new track? I need a circuit that does not exist in the list
is there a specific guide?
I'm here for the same problem.
If it's a permanent circuit, please let us know the name and location so that we can add it to the pre-defined tracks database.
Here's how to setup your own custom tracks:
1) On the main setup screen, go to the desired track mode, such as Circuit (swipe left or right to cycle through the modes, if needed)
2) Tap on "Select Track"
3) Tap on "Add New Track"
4) Instead of making a selection from this list, tap the "Add Custom Track" button at the bottom
5) You can now set the name and start / finish points as you like
. a) If it's a Circuit track and you don't set a start/finish point here, the first time you record a session at this track, you'll be given a large on-screen button to press as you cross the start/finish line.
