Results 1 to 20 of 33
Thread: MAF Curve for Roush Sealed Airbox
    Senior Tuner CCS86's Avatar
    Austin
    1,089
    Hi guys,
    Can somebody help me out with a MAF transfer function for the Roush Stage 1 MAF housing / airbox lid? This one attaches to a stock GT airbox.
    I have one Roush calibration from the repository, but have no idea which MAF housing it is for. Roush has been annoyingly tight lipped and refused to just send over the transfer function. After a bunch of pestering to at least confirm/deny the function I have matches, they claim "no, it is not".
    Much appreciated!
    Oct 2016
    Poland
    1,764
    Can't you just tune it?
    Austin
    1,089
    I could.
    I'm in the camp of minimal-to-no adjustments to the MAF curve. Using the stock GT500 MAF curve, I have been able to get my fuel trims very good. A MAF sensor housing / filter combination should be a very well calibrated device. As long as you don't make upstream modifications, there should be no reason for it to be inaccurate. With a known good MAF curve, if your fueling is off, the issue is probably elsewhere in the tune or mechanically.
    To attempt building one from scratch, when a calibrated transfer function already exists seems less than ideal.
    Oct 2016
    Poland
    1,764
    Building MAF curve form scratch takes 2 hours tops.
    Austin
    1,089
    I didn't say that it would take too long.
    I'm saying that doing it that way inherently builds error into the MAF curve, which screws up load calculation, etc. If there is an OEM calibration, which I'm sure there is, that is a more accurate way to go. I am using MU52 injectors on a Coyote, so there is no solid calibration data.
    Correct, having correct maf transfer will help you dial injectors much easier. here you have:
    90.3319473266602 93.6180572509766 97.4883728027344 100.955497741699 103.716499328613 105.887298583984 108.264801025391 110.923400878906 112.40470123291 115.534202575684 119.11710357666 123.263496398926 134.057205200195 141.253402709961 150.274795532227 162.580703735352 180.09049987793 187.144805908203 192.617401123047 199.054397583008 206.664398193359 215.335601806641 225.130996704102 236.495697021484 250.141998291016 267.027709960938 276.985595703125 288.609100341797 316.512786865234 335.321899414063 359.344696044922 391.028686523438 413.428894042969 439.216400146484 475.810089111328 525.508117675781 610.398681640625 661.541198730469 711.511291503906 1400
    680.388555
    604.789826666667
    529.191098333333
    472.224660340968
    430.557805688413
    402.779892973834
    375.001980259256
    347.224038706051
    333.335067929448
    305.557126376244
    277.779213661665
    250.001300947086
    194.445446679303
    166.667533964724
    138.889606830832
    111.111686906597
    83.3337669823621
    75.0003917260572
    69.4448106250728
    63.8892151047753
    58.3336340037909
    52.7780492979782
    47.2224645921655
    41.6668834911811
    36.1112987853684
    30.5557140795557
    27.7779217266493
    25.000129373743
    19.4445446679303
    16.6667523150239
    13.8889608633247
    11.1111685104183
    9.72227593879342
    8.33337615751197
    6.94448088226587
    5.55558515641623
    4.16668807875598
    3.61112974335578
    2.77779212760458
    0.755987294598422
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
    Austin
    1,089
    Thanks Carniggia, that data matches the curve in the Roush-575 file in the repository. Do you have any hands on experience with it, or know for sure that it is intended for the housing I pictured?
    Roush claims that the above data is not correct for this MAF housing (refusing to send the correct data), but I'm not sure how much I trust this claim.
    Doing some rough math, comparing the open area of the GT500 vs the Roush housing, the percent difference is pretty close to the curve difference, which is promising.
    I have 2-3 files from roush 11-14 and i have 2 maf curves for this year. Hausing on photo is defintely 11-14 Roush phase 1 hausing 575
    MAF above is with injector changed, could be this file was posted by txcharlie.
    Bellow is second maf curve i have and this curve is same in 2 files, they have smaller values, so i bet it will be correct one.
    514.071352666667
    363.554285708545
    312.502476923332
    262.478794001694
    229.366542916878
    216.925718175517
    194.171104828017
    173.146333216731
    157.800319688697
    148.440974256127
    136.077711
    123.981911582804
    98.2783468333333
    78.5470813338097
    71.8385391659748
    65.0032223972513
    60.8295089587846
    57.4965820631025
    51.9710652299584
    47.9122520880318
    46.1182480132931
    43.1091933094397
    41.3916656666235
    38.5209534576035
    31.7514644580687
    26.8375481978505
    23.1332104374206
    19.8068659581745
    15.1197456666667
    14.2125608906184
    11.1886119375265
    7.8622674582804
    6.46369141669313
    5.06511492450232
    4.38472611716434
    3.73457708774355
    3.56069999815757
    3.29610447602711
    3.11466761093816
    0
    83.3000030517578 101 107 114 119.800003051758 123 128 132 136 139 143.5 150 160.5 173 178 183.5 188 193 200 207 210 215.5 220 226 242 259 275 290 320 330 360 410 450 500 540 590 605 635 650 1485
    www.hd-customs.pl
    Austin
    1,089
    Interesting. Are you saying that you think the two different curves are for the same MAF housing, but with different injectors?
    Why would injectors cause any change to the MAF curve? Do you know which injectors are used in each calibration?
    Oct 2016
    Poland
    1,764
    Quote Originally Posted by CCS86 View Post
    Injectors can't affect Air Model - this is impossible. Must be something else.
    Since its few years I don't really remember, could be cai was changed, second one I have marked stock and fine tune I was doing, so I bet one is correct, injectors looks 47lb. First looks had 80lb injectors.
    Btw, you can use gt500 data injectors into coyote no problem.
    www.hd-customs.pl
    Austin
    1,089
    Quote Originally Posted by caniggia View Post
    I tried using the 2013 GT500 injector data and it was wayyyy off. I hoped that since it has multiplier tables for flow/breakpoint/offset vs rail pressure, using the higher Coyote inferred rail pressure tables would sort everything out. That was not the case.
    Since then I have slowly tuned flow, BP and offset based off of logged data, and have it fueling pretty well. I still feel like there is room for improvement though.
    Do you have some good #'s for MU52 injectors in a Coyote, you wouldn't mind sharing?
    Definitely wrong injector data affects maf model.
    Ill look when im home, I should have gt500 data installed in coyote 15 when I was upgrading roush.
    Send me your email pm
    www.hd-customs.pl
    Oct 2016
    Poland
    1,764
    If you swap the injectors only and if you have a correct injector data this change CAN'T affect fueling/air model in ANY WAY.
    That's correct, why correct data should affect. That's why ccs86 needs correct maf to setup injectors if he don't have or is not sure for injector data.
    www.hd-customs.pl
    Oct 2016
    Poland
    1,764
    Well the difference between wrong injector data and un-tuned MAF curve is clearly visible in data logs.
    Austin
    1,089
    How so?
    May 2016
    1,134
    The talk about injector data is kind of funny on a Coyote car without return fuel system... No fuel pressure compensation on these cars so it is a bit of a stretch to talk about perfect injector data on them.
    Austin
    1,089
    Quote Originally Posted by ridenrunwv View Post
    Is it?
    Have you datalogged rail pressure and found significant differences compared to the inferred rail pressure tables?
    Even if rail pressure varies somewhat, flawed injector calibration data will only make fueling worse. So, it's a silly argument to downplay its importance.
    May 2016
    1,134
    True the difference is not big but when trying to get to get exact it makes a difference. Luckily these ECUs are fast and have widebands so it is not that big of a deal
