Scanner hard to open bcz of crash errors
When I try to open Scanner I get errors some of the time, as follows:
Unhandled exception has occurred in your application.
Invalid Character in the given encoding. Line 18, position 18.
************** Exception Text **************
System.Xml.XmlException: Invalid character in the given encoding. Line 18, position 18.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.InvalidCharRecovery(I nt32& bytesCount, Int32& charsCount)
at System.Xml.XmlTextReaderImpl.GetChars(Int32 maxCharsCount)
at System.Xml.XmlTextReaderImpl.ReadData()
at System.Xml.XmlTextReaderImpl.ParseQName(Boolean isQName, Int32 startOffset, Int32& colonPos)
at System.Xml.XmlTextReaderImpl.ParseAttributes()
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(Stream inStream)
at ..()
at ..( )
at ..( )
at ..()
at ..( )
at ..( , )
at ..(EventArgs )
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallba ckDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallba ckHelper(Object obj)
at System.Threading.ExecutionContext.RunInternal(Exec utionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallba ck(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallba cks()
I included my files, in case they are corrupted.
7-14-18.Graphs.xml 7-14-18.Gauges.xml 7-14-18.Channels.xml
