Results 1 to 20 of 20
Thread: MPVI 2 wideband support?
    Jul 2018
    Houston Texas
    18
    Is there any way to hook up a wideband to the MPVI 2? I?ve tried using several different set ups connecting the wide band directly to the computer but that doesn?t work because as soon as you hit record in the vcm scanner, the computer drops the wideband connection. I?ve used aem?s data logging software just to see if i have communication from the gauge(I do). It?s getting data from the hyperterminal too
    13,582
    Nope, not yet. Several threads on this and you'll need the extra piece they are selling when it comes available.
    For now you can only use a can-bus gauge or wire the wideband into the computers AC or EGR circuit if using a GM computer.
    Jul 2018
    Houston Texas
    18
    okay thanks for getting back with me. I’ll look into wiring it up through the egr circuit.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Here is a tutorial we developed to help in interfacing widebands to both the MPVI Standard as well as the MPVI2 while awaiting the Pro Features/Hub Expander availability.....
    Ed M
    [email protected]
    Aug 2018
    3
    The tuning school did a video on what you're talking about using the AEM 3040. Its a really simpmle plug and play solution, i use it for WOT tuning
    https://youtu.be/QI33c_HeH3w
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by BDE View Post
    unfortunatle it is only viable for platforms that run the Can Bus (2008+ and some isolated 2006 and 2007 platforms)....other options are available for thos other platforms....
    Ed M
    [email protected]
    Aug 2018
    3
    Yeah like you said it only works on Can bus platforms. But, What are the other options?
    Sep 2006
    Syracuse, New York
    299
    I use the serial interface to get Wideband data on my MPVI2. Not the greatest resolution, but the data is there and there's no analog offsets to deal with.
    Sep 2006
    Syracuse, New York
    299
    I used this tutorial as a guide:
    https://www.evoxforums.com/forums/sh...ad.php?t=21747
    You'll just need a USB <--> Serial interface. I picked mine up on Amazon for $6.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Aug 2018
    3
    How does this work in the vcm scanner for the mpvi2?
    Youre saying this will work for both Can and non can pre 2008 vehicles?
    Sep 2006
    Syracuse, New York
    299
    Yes. Once the serial cable and wideband are hooked up, you simply add a channel --> Serial --> AEM Wideband.
    VCM Scanner auto detects the serial and does the rest for you.
    Was a pretty painless process in my car
    Mar 2007
    Florida
    3,772
    Did our read the Tutorial above (thread #4) ??????
    Ed M
    [email protected]
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    This could all be solved with a simple addition to the scanner: user defined CAN channels.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Quote Originally Posted by HackAbuse View Post
    Agreed. Serial wideband is the way to go. No messing around with voltage offset issues or grounding issues. Just plug it in and go.
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Definitely, but it would still be nice to have working I/O on the interface itself.
    Steve Williams
    TunedbyFrost.com
    Jun 2012
    Canada
    154
    am I missing something. Why is the new mpvi2 difficult to hookup critical much needed wideband for tuning. without a wideband or correct fast accurate lambda input how can you tune? I was excided to upgrade my mpv1 to mpvi2, and to start tuning the new added vehicles which are now supported with this new interface. disappointed.
    Tuner evolmotorsprt's Avatar
    Aug 2018
    Salt Lake
    115
    Quote Originally Posted by obd2 View Post
    ^^This! I'm waiting with bated breath over here.
    Jun 2012
    Canada
    154
    I guess the best way to use the mpiv2 would be to use both mpiv1 and 2. mpvi2 to write mpvi1 to log.
    Aug 2018
    4
    Yeah but if your car is 07+ like you said, seems like the best way to integrate a wideband would be with the AEM X series with obd2 support, that way you would seemingly be able to run the gauge alone without having hp tuners plugged in, or plug in hp tuners and still utilize the gauge. Am I correct in assuming this is how this works?
    Dec 2005
    604
    Yes. The gauge works, whether or not the MPVI/MPVI2 is attached. It really doesn't even care if the OBDII connector is plugged in, as long as it has the power and ground wires connected.
