When setting up aux inputs (dual widebands) with the Enhanced IO Connector, are grounds 5 and 6 both used?
I know to use pin 1 for the driver's side wb and pin 2 for the passenger's side. Pin 5 is the ground which is common to both wide bands at the source.
Do I need to jumper pins 5 & 6 together?
Please and thank you.
