Results 1 to 14 of 14
Thread: HP vs DIABLO
    Red face HP vs DIABLO
    hi guys ..
    as it is in the title .
    what will happen if i tune a car that already married to a diablo trinity ??
    and if its bad thing how to slove it ? just take the hp file from the car then unmarry from the diablo then pot the hp file again ?
    thanks in advance .
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    584
    I'm no pro, but I would capture Diablo tune, return to stock, capture stock tune with HP, make changes to that tune doing a compare with Diablo tune and then loading that tune with HP.
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    Nov 2009
    All Around
    3,149
    depending on the year of your dodge, if you tune with HPT you will not be able to use diablo anymore due to changes to boot mode.
    Nov 2016
    Austria/Europe
    49
    I still use my diablo predator for fast diagnostics. My recent tune was built up on a diablo tune, no problems at all
    Quote Originally Posted by SultanHassanMasTuning View Post
    my car is 2007 and i pot hp tune in above of diablo tune , and i still can use the diablo to tune gear and lot of stuff with no issue so far .
    Quote Originally Posted by 123gr View Post
    ya me 2 but am using trinity ,, i didnt see any problem but wanted to make sure cause i saw some tuners say you must take the diablo tune first out then do hp .
    Jul 2015
    928
    What year of car? The older stuff there wasn't any problem. But I've heard issues with the 15+ PCM's that have to be sent in to be unlocked.
    Nov 2009
    All Around
    3,149
    you can read DTC with the diablo device just like any code reader, but especially 2013+ if the car was tuned on HPT and you want to use diablo to tune it
    you will be locked out.
    alright thanks all for helping ^^ now am just gonna use it tune the differential ratio when i change mine cause i didnt find from where to change it in hp
    Jul 2015
    928
    You use HPT Scanner to change it.
    Feb 2018
    16
    I use hptuners but my married predator was the only thing that allowed me to change my gear ratio. Shame 650 device but still need my old big blue for simple stuff.
    Mar 2009
    S. Florida
    584
    Quote Originally Posted by Bryan86 View Post
    HP never did a full write on my gear change, left me without ACC/FCW. Was also told that Diablo was the one to get it fixed.
    Jun 2018
    Dubai
    62
    i do that most of the time no issue with it
    Jeep wrangler 2012 automatic, sprintex supercharger, 9lbs of boost, 4.5" lift, fox 2.5 internal bypass shocks, 4.88 gears, 37" tires,
    Ford Mustang Shelby gt350 2017, airraid air filter, jlt catch-can,
    ok then how about mooding more with the daiblo ?
    as example if i did an hp tune on an already written diablo tune then i wanted to reach or lean the fuel or changing any thing by the diablo , is that will go up to the hp tune ? or it will cancel it ?
