[QUOTE=joe53016;557383]
"(Equivalence ratio Commanded [sensor]) line should be pink"
Thanks for this man! You put some time into writing this. I learned how to get the correct working address from the variable wizard as you described. That was huge for me! Thank you!
So when looking at my EQ error ratio math, neither of the lines were pink. What I get from this is that the EQ error ratio math is working correct then? Also I believe it is working being that I do get a value in my graph when using this math.
However in the AFR error math formula I found that the air fuel ratio sensor line is pink. So I followed your instruction and created a new user math using my WB address I found in the variable wizard and I got the AFR error to work in a graph.
Thank you for your time.
