Results 1 to 11 of 11
Thread: DoD parameters
    Jun 2006
    Brandon, MS
    17
    DoD parameters
    I was wondering how soon DoD parameter editing will be available.
    Mainly just looking for a way to disable it. The gas mileage is nice, but the constant bucking of it engaging is very annoying. The ECM has not been too friendly to my other somewhat crude attempts to disable it.
    Thanks again for such a kick ass editor!!
    Michael
    2007 Black Silverado 5.3
    TR220 112lsa, Pacesetter LTs, 44lb Injectors
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    Yeah, lookin at some new 'lanches, and id like to know if we can turn it off with our current releases of the editor. If not, will it be ready in the near future?
    EDIT: As ive never been under the hood of a DoD beast, is it simply a sensor that can be unplugged? My theory origionally was that the answer is no, and that it runs off of the speedo, to determine that the speed has been constant for X amount of time. Anyone know how it calculates/decides when to engage?
    Jun 2006
    Brandon, MS
    17
    I don't know all the factors that decide whether it comes on or not... but it is more based on engine load. Cruising on the interstate when you peak the top of a hill and let off on the gas a little bit would be one situation. Pretty much any time you ease up on the gas without letting off completely it will come on.
    To disable it the first thing I tried was disconnecting the wires going to the oil solenoids that actually activate V4 mode... however the computer kinda goes into sorta a default mode and cuts the fuel to those cylinders anyways... so its like shooting yourself in the foot.
    The only easy way I have found to disable it is to disconnect the oil pressure sensor which is plugged into the manifold where the solenoids are housed. Without a valid oil pressure signal DoD is disabled. Of course then you are greeted with an oil pressure light in the dash and in the DIC all the time. Plus no way of know if you actually have oil pressure without an aftermarket gauge or something. However it drives soooo much smoother on the interstate with it disabled.
    I would like to try adjusting the settings so maybe the transition to V4 mode won't be so harsh... or if that won't work then just disable it completely.
    From the factory the TCC duty cycle is set so low that when the V4 mode comes on the engine rpms actually jump up for several seconds. I cranked up the TCC duty cycle to solve that... but now it just jerks really bad. Disabling torque management makes it even worse... almost like someone rear ends you.
    DoD is not my friend
    Michael
    Jun 2006
    Cape Coral, FL
    860
    Thanks Mike,
    So does anyone have a timeframe of when we'll have this feature in the editor?
    it's nearing the top of my list.
    Chris...
    I count sheep in hex...
    Jun 2006
    Brandon, MS
    17
    Awesome... thanks for the reply.
    Michael
    Jun 2006
    Cape Coral, FL
    860
    Yes! Thanks Chris!
    No more 4-8-4-8 surging for DoD people!
    Sep 2005
    7
    It says on the web site that DoD disable is now available for "applicable vehicles", but I can't find the feature in the VCM suite for the Saab 9-7X 5.3i?
    28,275
    would you mind posting your file?
    Sep 2005
    7
    Ok, here's the stock file.
    28,275
    huh...they might not have added the enable/disable switch on your OS yet...you could always contact support in the meantime to see if they can disable it for you temporarily until the add it to your OS.
