Results 1 to 3 of 3
Thread: Driver Demand vs Gear Question
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Is there anything to adjust driver demand vs.gear ratio?
    For example, if I am 50% pedal position and let's just say it is 70% throttle, when it downshifts the higher axle torque is pulling throttle back to say 40% for the same 50% input.
    I have a log of what I am talking about, I just can't find which one it is in.
    I would like to be able to stop that from happening. These driver torque demands are annoying. My brain/foot are calibrated so when I give it 50% throttle I really mean I want the throttle to open 50%
    Sulski Performance Tuning
    Mar 2010
    Texas Hill Country
    3,299
    These are torque based controllers, your 40% throttle with a lower gear ratio gives the same axle torque as 70% and a higher gear ratio.
    Of course theoretically to get an auto to down shift you need to increase pedal position so technically you won't have the same 50% pedal input.
    You command a torque with the pedal, the ECM picks a MAP and spark to get there (and if auto it picks a gear ratio also). If the MAP it needs is 40% throttle then that's what you will get.
    May 2003
    South FL
    1,371
    You need to get into the TCM. I was more descriptive in the other thread. You're going to chase your tail trying to get what you want via the Driver Demand Tables.
    [email protected]
    Owner/GM Calibrator
