2018 Lift pump voltage table
Does anyone know if this works, I'm out of lift pressure in a supercharged car, I raised the voltage from 12v to 16v in the relative high flow area but saw no improvement.
It does not log either.
Interesting, I pushed to 16v and saw no gain from 12v so didn't bother wit 18v, maybe. Lowered the boost for now. Do you happen to have a log and the power of this?
No logs.
They also replace the pump with a dw400.
The 2018 F150 Whipple stage 2 kit will pull to a little past 7000rpms before the lift pump drops below 60psi with the stock fuel pump
