how do you use the link sections in the virtual torque section?
the link selection only works when you use the math box at the top so it would be a global change, rather than a logged error in a graph.
Thanks. Does the extrapolate function work correctly/reliably?
So is the common theme it is better to do all the different timing graphs manually rather than calculate coefficients, if you can?
different people do it different ways
