Results 1 to 10 of 10
Thread: 2006 GTO Ambient air temp sensor
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    Anybody know where the Ambient air temp sensor is located?
    Not the IAT (Part of the MAF).
    It suddenly started reading 32 degrees constantly last night on VCM scanner.
    never changing. IAT is normal etc.
    RockAuto shows a weird connector for "Ambient Air Temp Sensor Connector", but not the sensor itself...
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    FIC1000 shorty Injectors
    DW300C Fuel pump
    UPP GTO Auxiliary fuel system
    BoostDistrict LSA Conversion
    BTR Stage 3 PDS Torque cam and kit
    Kooks Longtube headers with High Flow Cat mids
    BoostDistrict LSA CAI with LS7 MAF module
    Mickey Mouse Catch Can
    Hinson 1/2" lowered Engine Mounts
    Magnaflow 3" Cat Back Competition Exhaust
    PLX DM-6 Wideband
    Turbo Technologies Full Flex fuel Tune
    13,565
    Don't quote me here but I swear on some computers it never reads right. I've logged them before and they'll read like 0 or -40 even though the vehicle has one equipped.
    If it's anything like my previous pontiac cars, they install them between the front bumper and radiator somewhere with a body clip style clip.
    7,649
    However, it doesn't exist anywhere in eSI. Searching 'AMBIENT' and 'AIR TEMP' none of the hits are relevant. Not even in the master components list.
    Do you have the GH4 RPO?
    Mar 2018
    110
    that was the same info I saw on RockAuto as well.
    Frustrating as I have scoured thru my AllData for 04-06 GTO's, and see it mentioned, but nothing in the diagrams anywhere.
    I know it has to exist, as the readings were normal before Sunday, then sunday late afternoon, they showed 32, and have been there since. IAT's are still reading fine, and temps haven't been that low here in a few days.
    I know it has no affect on the calibration, but I find it useful to compare IAT's to etc, and it's easy to log since it's provided to the scanner by the ECM.
    I wonder if the sensor is wired to the BCM or PIM and the bus queries it that way?
    AllData doesn't show any wiring for the PIM that I can find
    What is the GH4 RPO you refer to. all the lists of RPO codes I can find show that as a 2.28 rear axle
    *edit* AllData shows GH4 as "Additional Equipment, USA" so yes, I have GH4
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
    7,649
    Rockauto does list the sensor. Under "Heat & A/C".
    https://www.rockauto.com/en/catalog/...re+sensor,7000
    Service manual shows the sensor in the Grand Prix section - both wires are direct to the instrument cluster. Still doesn't exist in the GTO section. Is there a physical sensor on the car? Somewhere not far from the hood latch area?
    7,649
    Found it for Grand Prix and G6, just to prove that I don't suck at eSI-stuff-finding.
    Mar 2018
    110
    I need to dig around and see if I can find it there.
    Didn't see anything obvious, but may need to pull the OTR CAI off to get more room to see.
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
    I remember reading somewhere that there is no ambient air temperature sensor. The car reads what the ait is at cold startup and uses that as "ambient". I've taken apart a couple GTO's and have never seen an actual sensor like there is on escalades for example.
    Mar 2018
    110
    I had the front clip off for other things, and couldn't find anything either.
    It is now showing proper temps again, but makes no sense that IAT was correct, but the ECM was always showing Ambient as 32Deg F no matter what.
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
