Results 1 to 9 of 9
Thread: What is the purpose of Case Learn and Cylinder Balance
    Jun 2006
    28
    What doe Case Learn do? I have done searches on the board and no thread state what it does or what it is for. I tried it, it worked for me, seems like people are having trouble with it but what is it for ??
    Also Cylinder balance what is that for ? Is it just a diagonostics check to make sure all cylinders are working or to test for a bad cylinder. MY results ranged from 96% to 101 %.
    Apr 2005
    33
    i would like an answer to this too
    1999 Corvette
    Apr 2003
    Almost 2000 feet.
    7,876
    Case Learn is only utilized when replacing an engine or a PCM with a new one. Possibly if you have done a cam change. What it does is syncronize the cam signal to the crank signal.
    Cylinder balance is usually used to determine if you have an injector/cylinder that is out of whack. If you really had a bad cylinder, the good ones would show more RPM drop as you have more than one down when the cylinder balance test runs.
    HTH
    Always Support Our Troops!
    Nov 2005
    Someplace high in the Himalayas
    770
    EC,
    Would it be wise to do this on a stock car? Is it possible there could be a performance gain if it wasn't right from the factory?
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    Apr 2003
    Almost 2000 feet.
    7,876
    Once the CASE learn is done it is not necessary (or advisable) to do it again. It's basically a setup utility.
    Apr 2005
    33
    Thx for the responses
    1999 Corvette
    Jan 2007
    4
    Quote Originally Posted by EC_Tune
    So, is this something you would do to start tuning a cam swap ?
    Nov 2002
    477
    generally no, won't hurt anything, but generally only needed if swapping PCMS or overwriting entire PCM... you'll notice very rough idle and difficulty starting if it's needed
    Mike Horist
    00 WS6 (TA) | 04 WS6 (GTP Comp G)
    Mike \\#at&\\ horist \\&dot$\\com
    BOTH cars HP Tuners Tuned
    Jan 2007
    4
    gotcha
