*Older ECUs counts in the opposite direction than newer ECUs when referencing start and stop positions. You have completely recalculated the injection timing (including the make-up) to match the camshaft when swapping between ECUs generations. My truck is a 98 but the ECU is a 03. I've been swapping back and forth with a jumper harness.
