Results 1 to 8 of 8
Thread: Limited PIDs from GM E99 PCM
    Mar 2010
    Goleta CA
    122
    I'm trying to scan the PCM in a 2019 ZR-1. I can only read a very limited about of PIDs when I try to add channels. For comparison, I can read far more data from the E38 in a 2012 Z06.
    I know there is more data coming over the DLC because one of my sources is a high-level engineer at GM who worked on the LT5 engine development and he told me the PCM sends a lot more data than what I can read with PCM Scanner.
    Can anyone give me an idea about what the problem might be?
    Hib Halverson
    Just Another Tuner in Training.
    28,285
    normal.
    applications that aren't supported by us will likely only show SAE pids.
    Mar 2010
    Goleta CA
    122
    normal.
    Not sure I understand. I'm trying to use VCM Scanner to log from an E99. You don't mean to say that HPT doesn't support its Scanner application, do you?
    Hib Halverson
    28,285
    Quote Originally Posted by Hib Halverson View Post
    ZR1 is not a supported application, therefore minimal pids.
    Mar 2010
    Goleta CA
    122
    Is HPT planning further development of VCM Scanner such that it supports data logging from the E99 PCM?
    Hib Halverson
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Update your beta. A lot was added last week, and I'm sure more will be added in the wake of their release announcement. FICM logging is restricted to basic SAE parameters right now, but the E99 has most things the E92 has currently available.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Mar 2010
    Goleta CA
    122
    I wasn't using a beta but I DL'ed it and the E99 controller is now supported.
    Thanks for the tip "DSteck".
    Hib Halverson
    28,285
    Yeah sorry man, couldn't tip my hat until we had actually released it
