Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
Thread: 3.5 ecoboost owners
  1. #41
    Oct 2021
    Oklahoma, Mexico
    10
    Just bought my 2015 SHO, here is my stock read, I will be updating as I make changes to help others learn and to allow the community to critique me and provide constructive criticism if you wish. I'm from the diesel tuning world and LS based as of recently. I'm breaking out into gas turbo direct injection which I've come to understand is similar to diesel except these engines aren't as forgiving as a diesel. I've got off road downpipes ordered and when I get them installed I'll post my updated file here for others to learn and see if I can improve upon it. For too long now too few people know what to do and they charge a premium for it, so we need to create and share our tunes so that we can all learn from each other as a group.
    AS FOUND.hpt
    2010 Ford F350 DRW 4X4 6.4L POWERSTROKE (thatslo6fo)
    2002 Cadillac Escalade 6.0L AWD
    2004 Jeep Grand Cherokee 4.0L 4X4
  2. #42
    Mar 2022
    3
    2018 F150 4X4 w/ 3.5L EcoBoost Stock ECM/TCM Tune
  3. #43
    Feb 2024
    1
    ISO 2014 f150 3.5 bone stock file
  4. #44
    Nov 2023
    n/a
    78
    i have a 2011 f150 3.5l ecoboost has bd manifolds and the exhaust ports and manifold ports have been ported a bit bigger. has arp head studs and a complete rebuild. costel turbos that are pretty much a stock replacement. i would like more hp out of it i added some but would like to go more with it . no experienced enough to no whats moderately safe running one step colder ngk plugs. cold air intake. stock intercooler. the truck has torque but seems to lose it at the top end .
  5. #45
    Nov 2023
    n/a
    78
    heres a SCT 87 octane tune on a 2011 3.5l ecoboost runs like crazy. 0-60 6 sec with a crew cab full size f150 id say i saw a 1-2 + mpg increase
  6. #46
    Nov 2023
    n/a
    78
    heres is a stock file from a 2013 3.5l ecoboost f150 fx4 3.73 rears should be same as a 2014 3.5l
  7. #47
    Apr 2022
    Michigan
    9
    Thanks for posting Jeremy.
    Is the 2011 the same engine and trans config as the 2014 F150 ecoboost lariat? I have the 3.5 with the 6R80 trans/
    Would this SCT tune drop right in?
    Also how did you come about the sct tune? I had always heard they were hard to crack open and find??
    Thanks in advance!
    E-85 Flex Fuel, Texas Speed 2'' primary ceramic Long Tube Headers, High Flow Cats, LT2 Intake Manifold, LT5 Soler Performance Throttle Body, Rotofab, ZL1 1LE wheels are tires, Silvers coil overs, BMR strut brace, Black lugs, Recaros, Red belts and kick panels, HP Tuners, AEM Wideband, Sunroof and Bose, Elite Catch Can, Diode Dynamics smoked LED sidemarkers, NPP exhaust, Graphite black ground effects, 3 inch Drop, T93 Unlocked
    https://www.youtube.com/@ericknickerson
    Please subscribe
  8. #48
    Oct 2018
    19
    Here is the stock tune pulled from my 2018 explorer sport 3.5 EcoBoost. I'll post updates to it here as I go with a change log.
  9. #49
    Nov 2023
    n/a
    78
    Hi i just see now that someone was wondering if that 2011 sct tune would roll into a 2014, the 11-12 are different than 13-14. i have a 2013 sct tune in hpt format. as far as getting the tune all i do is tune the truck with sct then readout with hpt. its just a 87 oct preloaded tune that sct has. helps oiut on the power and a bit more mpg. you can do a comparision on you stock tune and copy the differences over that you want . i am always a little scared flashing a file from a different os number different ecm thats why i like to just copy diferences over that hpt shows. fuel tank size and other options might be different and hpt doesnt show that.
  10. #50
    Oct 2018
    19
    Here is a stock tune for a 2018 ford explorer sport. I will post updates to the tune here with a change log as I build the car.
  11. #51
    Aug 2024
    Colorado
    2
    19 Navigator with 3.73
    Stock.hpt
  12. #52
    Nov 2023
    n/a
    78
    anyone know what a good time is for 1/4 mile on a fullsize f150 32in tires 2.5in level kit. crew cab weight is around 6,000 lbs 1/4 mile time im running is around 14 sec. thats with some e85 prolly 30% was curios what is considered quick? lol
  13. #53
    What year range? Guessing since your 6,000 pounds your talking 11-14.
    17 and newer I don't consider "quick" until your in the mid 12s. Usually a good 93 tune or e30 with basic mods like intercooler and colder plugs can get you to mid 12s on those.
    Add .75 or 1 second for 11-16 trucks.
  14. #54
    Nov 2023
    n/a
    78
    ok mine is a 2011. 315,000 miles 35,000 miles on engine rebuild, has one step colder plugs and tuning, otherwise its stock, so i was happy with what it can do , if im going any further next step would be a intercooler. my turbos i think could use a upgrade as they have 140,000 hard miles on them and the left one has some excess bearing play, ive been able to do 20 psi boost but normally get around 18 psi ,
  15. #55
    Intercooler and HPFP with a good tune will get you into the 12s. 18 PSI is plenty on a Gen 1. Any more than that is blowing your turbo efficiency out the water. With a larger more efficient Intercooler you can be around 16-17 PSI and still get where you want to be.
  16. #56
    Nov 2023
    n/a
    78
    do i need head studs on a 12 sec gen 1
  17. #57
    Nope.
  18. #58
    Jun 2025
    1
    Quote Originally Posted by davidsiebert2 View Post
    heres an aggressive 2012 ecoboost e30 tune file, 18-20 psi and 21-23 deg timing. nice decel pop when manually downshifting and burble when slowing down in drive. good for low 12s with the family in the car.
    a 2016 sho 3.5 ecoboost file on e30 also good for high 11's low 12's at full weight.
    2011 f150 6.2 good daily file with great shift schedule for towing and in drive.
    Attachment 108420
    Attachment 108421
    Attachment 108422
    hi, is the 2016 SHO file utilizing the stock fuel pump? Tia
  19. #59
    May 2008
    14
    Ill help with this. Here is a stock 400hp 2020 Expedition Platinum 4x4 tune.
  20. #60
    Jul 2025
    2
    Thanks for posting this stock tune I?ll check the differences between this and bronco/ranger raptor
