Results 1 to 7 of 7
Thread: Why is my commanded AFR 12.4?
    Tuner in Training clshortt1's Avatar
    Mar 2019
    Edmond, Oklahoma
    49
    Newbe here. First tune. First scan. Just getting started. Wideband connected through AC pressure point. I cant figure out why my commanded AFR is at 12.4. Can anyone point me in the right direction?
    MY MAF is disabled and running in SD mode.
    Thanks for the help.
    13,579
    Even though flex fuel is disabled, it's possible the alcohol content is stuck as some random value causing this issue.
    Just make the stoich table one solid value. So 14.68 for regular pump gas or at whatever stoich ratio the fuel you are running is.
    Mar 2019
    Edmond, Oklahoma
    49
    5FDP. Thanks for the reply. I'll see if I can find it and make that change. I'm running pump gas so 14.68 would be correct. I went over everything that I have read and watched and could not seem to find it. That was one thing I did not look at.
    The "Default" Flex Fuel sensor setting for failure is set to 38 percent which pretty much corresponds to your 12-12.4 AFR as it warms up.
    Mar 2019
    Edmond, Oklahoma
    49
    Jeff7577. Thanks for the reply. I'll check that as well, if I can find it. thanks for the help.
    Mar 2019
    Edmond, Oklahoma
    49
    5FDP - I set the entire stoich table to 14.68 and that seemed to do the trick! Thank you so much.
    Jeff7577 - I ran out of time last night to try anything else. I'll will look at your suggestion tonight. Thank you so much.
    13,579
    Them flex fuel OS can get screwy sometimes.
