Results 1 to 20 of 26
Thread: High pressure desired Pump settings
    Jun 2012
    Canada
    154
    has anyone had good results in tuning fuel system via HP tuners? tried raising High pressure desired to a higher number in the upper cylinder mass. the desired never change, the desired pressure remained at 2900 pis even after I up it to 4000 which surprised me. I realise by raising the desired may not do anything to real fuel pressure, but I never messed with the stock settings. did anyone have good results in tuning fuel pressure? my current setup has a low side fuel pump, just trying to see if commanding higher fuel pressure from the mechanical pump would get me more fuel.
    Depends in the pump capacity.
    Example in a L83 stock in table 2200 psi and I increase it to 2650 psi which actually raises 2650 psi.
    If you are commanding 2900 psi in a stock L83 it will reach hardely 2700 psi at a max.
    Maybe you need a bigger cam lobe to increase it more than 2900 psi.
    Jun 2012
    Canada
    154
    Quote Originally Posted by ahmedabri97 View Post
    totally agree this is an LT4 stock is 2900. so what you are saying is you raised the desired and confirmed via datalogging that the actual desired changed. did you perform a write entire or calibration. I ran out of time yesterday and got frustrated with datalogging. I downloaded the latest hp tuner version (Do this every week) which this time also contained a firmware update. going to open a ticket due to a few pids going blank on the chart even if they are being logged.
    Mar 2010
    Texas Hill Country
    3,299
    there are pump max limiters you need to adjust also so that you can blow out your seals.
    Jun 2012
    Canada
    154
    Quote Originally Posted by Higgs Boson View Post
    Thanks for the reply. what did you set your z06 pressures to? did you successfully raise DI pressure by raising desired. looks like both the z06 and ctsv have the same pump settings and looks like seal protection is disabled
    Aug 2009
    Calibrating
    3,378
    Max stated in the ECU on the lt4 is 27.5 mpa, I’ve routinley used 24mpa on the desired and hit it as well!!
    Also just recently learned some changes that work well with cam lobes
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2014
    Central, LA
    737
    Max stated in the ECU on the lt4 is 27.5 mpa, I?ve routinley used 24mpa on the desired and hit it as well!!
    I think alot of folks recently learned the same thing thanks to Mr. Banish lol
    Aug 2009
    Calibrating
    3,378
    Quote Originally Posted by sevinn View Post
    Smart fella!!
    14 Gen 5 Viper
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by obd2 View Post
    All my DI stuff is set to stock but I am running port injection. On systems where I need to push the stock system I have raised MPa also, my comment was just tongue in cheek.
    Yes I confirmed with the actual rail pressure.
    Write calibration.
    I have no experience with LT4 but in a LT1/L86/L83 mech. pump maximum I tried with success is 2750 psi with a 32% cam lobe.
    Without a cam lobe they normally max at 2650 psi.
    Jun 2007
    Close to my Z06
    271
    My highside gets to 2300 on my C7Z, would going to 24 Mpa get me back online? or hardware is needed at that point?
    Jun 2012
    Canada
    154
    Smart fella!!
    WOW! are you saying his video is informative, and help you to get to the next level? I am sceptical of any new material, 2 years ago I got the tuning school guide and it was joke, the revised version was much better but the injection cycle is not 100 % correct. By the time they gave me the revised version was too late, had already figured most of it. I still have so much to learn
    Aug 2014
    Central, LA
    737
    Banish puts out really good stuff. There were some tidbits in the video that I'd never seen discussed on these forums at all, and the SOI section was probably the best I've seen.
    Jun 2012
    Canada
    154
    you are referring to HP max pump, why would you drop it from 27.5 to 24. when data logging with stock settings lt4 run at 20 max. are you matching your desired also to 24?
    Jun 2012
    Canada
    154
    Jun 2012
    Canada
    154
    the lt4 threshold is set to 27.5 = 3916 psi. I presume setting desired to around 3500 would be a good start, or am I missing something.
    Aug 2009
    Calibrating
    3,378
    We are talking about 2 different things... desires pressure is 20mpa stock, I usually jump it to 24
    My desired and actual match
    14 Gen 5 Viper
    Aug 2009
    Calibrating
    3,378
    In 2014 I used a 360 degree wheel that gave a visual ad in SOI, we had it mostly correct back then, but an OEM calibrator to help us fine tune that helped..
    Going to do my cam cars a little different now
    14 Gen 5 Viper
    Aug 2009
    Calibrating
    3,378
    Not to say anything too terrible, but they get most of their info from the forums and capitalize on it lol.. just wait they will have a new book out soon..
    Their is a couple of “yahoos” local to me that “learned” the tuning school way and think they know how to tune.... it’s very entry level
    14 Gen 5 Viper
    Jun 2012
    Canada
    154
    Thanks Ben, maybe I should learn how to read lol. read it a second time made total sense. Cheers
