Results 1 to 8 of 8
Thread: PO315 Code
    Jan 2017
    48
    PO315 Code
    I have done the crank trigger relearn a few times now. It says successful on relearn but check engine never goes away.
    May 2019
    8
    I just posted the same thing in misc. What vehicle ?
    Jan 2017
    48
    2016 Ford Mustang GT
    May 2019
    8
    Yeah I'm having it on 2011
    Jan 2017
    48
    Going to try returning to stock and run relearn and then load adjusted tune and try and reset.
    Jan 2018
    203
    same issue here; usually goes away after a few weeks
    Feb 2012
    TEXAS
    644
    if the re-learn continues to post check engine light check these Possible causes, Faulty Crankshaft Position (CKP) Crankshaft Position (CKP) sensor harness is open or shorted Crankshaft Position (CKP) sensor circuit poor electrical connection Damaged crankshaft pulse wheel teeth. you could also try using an SCT device if you know someone that has one..
    Jan 2017
    48
    Okay guys I put stock tune back in car and did a crank relearn and was able to clear the check engine light. So I don't know why it worked but it did.
