Results 1 to 7 of 7
Thread: afm codes wont clear
    Feb 2014
    34
    i have an 09 silverado 5.3 pickup that i removed the afm with a block off plate, new non afm lifters and a non afm cam. runs and dries great just cant get p3401 p3425 p3441 to clear. i clicked on the disable dod master switch to off and even deleted the codes and un clicked on ses enable. still the codes come on. what am i doing wrong?
    13,576
    If it not popping the check engine light and just come up as a previous pending code, leave it be and it should just go away on it's own.
    If you flashed the file with the changes set to no error reported, that is all you should need to do.
    Feb 2014
    34
    Its labeled as permant. Cant pass emissions. It's been on there for months.
    Apr 2011
    Chicago, IL
    763
    Do you have an actual ses light on?
    Mar 2019
    5
    There’s a brief discussion regarding permenant codes here:
    https://forum.hptuners.com/showthrea...d-when-scanned
    https://forum.hptuners.com/showthrea...l=1#post461354
    Only workaround I could suggest is to re-enable DOD, plug in a known good DOD valley with the solenoids (even just laying on top the engine, the PCM should see that they’re there), perform a drive cycle and see if the codes go away. Maybe get it emissions tested if they do, then set DOD to off as well as error reporting. Remove the valley/ solenoids and see if the codes return.
    Feb 2014
    34
    Quote Originally Posted by TCSS07 View Post
    no just saved as a permanent code
    Feb 2014
    34
    Quote Originally Posted by KKevlar99 View Post
    ill give that a try
