Results 1 to 3 of 3
Thread: MPVi 2 Wideband help!!
    Advanced Tuner coachcrow56's Avatar
    Dec 2004
    Longview, Texas
    260
    After fussing and fighting with this new software for 2 days, I finally got some things to actually work in the Scanner Graph. I can monitor LTFT, and my LC-1 Wideband, but I have not conquered the AFR ERROR Graph.
    When I run the Scanner, my AFR Error graph shows that part of it is working. By this I mean the blue box moves around the Graph, but there are NO NUMBERS in the boxes.
    I am going to Post a copy of my Scanning Config, and hopefully someone will look at it and find what I am doing wrong.
    The file I attached doesn't look right.
    3.2 Pulley/CAI/1.6 HS Rockers/Hi Energy Comp Cam 76-802-9/LS7 Lifters/ZZP Intercooler/Headers/2500 Stall Converter/Autolite 104's/ZZP Fuel Rails/100 shot NOS/GMPP Sway Bars//I forgot the rest!!!
    Are you trying to set up your scanner to do VE error log or the MAF error??
    55 Belair swapped 2000 LQ4, 4L80E, 873 cast iron heads have been swapped for 853's, truck manifolds, 2 1/2 inch exhaust, glass pack mufflers, no cats.
    Mar 2019
    16
    I'm having the same issue, and i'm pretty sure he is setting up for MAF, but either way my AFR err does not log to either MAF or VE graph set ups.
