Results 1 to 15 of 15
Thread: Do weather condition effect VVE ???
    May 2008
    46
    I did my VVE tune in 100F and high humidity...
    Does anyone know how weather conditions effect VVE tune ??? If i was to scan in 60F weather, would it require changes ??
    Anyone know ???
    Aug 2009
    Calibrating
    3,377
    Iat is part of te formula and is directly related to ambient temps so yes it is effected
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    I think theres an editable field that says what temp it was calibrated in. It says 68* stock and I zeroed mine in when it was that temp outside to be sure. I?m pretty sure that?s what the description stated
    May 2008
    46
    i completely missed that VE Base Temp setting... fail... i am guessing this is my IAT not ambient temperature ??? Can i just set this to 115F as that is what my IAT were ??
    BTW car is big cam, procharger, MAF breakout.
    Humidity would if you havent address the humidity table.
    May 2008
    46
    Quote Originally Posted by Phil'sC5Vette View Post
    Are you talking about spark humidity table ?? i don't see one directly related to VVE.
    Jun 2007
    Close to my Z06
    271
    How would you go about tuning for humidity?
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    136
    Turn off the temp setting option, tune VVE, then turn it on with your actual temp displayed in the PID. The car references the ambient temp. And watch out for the reflash which makes ambient read 32degrees, mine has done this a number of times in the past. Random stuff to watch out for.
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
    Feb 2008
    665
    Quote Originally Posted by Camaro6 View Post
    The trucks do this A LOT! Hahahaha.
    2017 Silverado LTZ
    Running the vehicle at 55 mph for 2 minutes should get the ambient reading back to proper.
    I got the 32 degree ambient issue also after flashing my VVE logging tune to the car. How are you correcting? Just flash again?
    Aug 2009
    Calibrating
    3,377
    Just drive it and in about 10 minutes it goes back to normal temp
    14 Gen 5 Viper
    Thanks Ben. So if I am doing my VVE tuning and corrections in 91 degree ambient tenps outside, I need to set the base temp to 91 degree vs 68 when I re-enable tenp correction?
    Mar 2010
    Texas Hill Country
    3,299
    I only tune VVE when it's 68 degrees outside.
    Quote Originally Posted by Higgs Boson View Post
    Dangit Higgs. Now I gotta download that weather app
