Results 1 to 9 of 9
Thread: Testing the VVT tables on dyno???
    Jun 2010
    559
    What will they help on, I try half the timing table to zero them and truck doing the same power on a stage 2 cam from TSP.
    Nov 2009
    All Around
    3,149
    i would zero it would and take a hit then retard
    Depends on the cam phaser limiter if it is a 0 degree lockout then playing with vvt will not help.
    Log actual intake cam angle.
    Jun 2010
    559
    Quote Originally Posted by SultanHassanMasTuning View Post
    I have never retard it and test it.
    Jun 2010
    559
    What will the actual intake cam angle log have to read?
    So If the phaser limiter it’s installed on another degree will it gain power?
    If a zero degree cam phaser ( lockout) is installed the actual intake cam angle will read zero at WOT.
    If you have freedom to play with vvt start with zeros in the table then try to retard 2 degrees at a time until you reach the best airflow.
    Jun 2010
    559
    So at zero degrees I won’t see nothing?
    I’ll have to try it, its there a possibility something goes wrong it it’s to much retard on timing playing with the VVT tables?
    They phaser limits the amount of retard. If you installed the phaser limiter kit you are ok, if you didn’t then you can have issues. I played around with it and you will get an error code and go into limp mode if it’s retarded too much.
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    144
    N/A no VVT down low is best. S/C I found no vvt at all is best for power gains
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
