Results 1 to 3 of 3
Thread: Car freaks out after WOT, only in MAF mode???
    Baltimore, Md
    1,208
    E67, speed density it never did this but switched to MAF mode because hit a wall where it seemed not to be able to calc properly past a certain power level.
    Make clean pull everything looks perfect but after youll hear a pitch change and TPS at idle seems to lock out at a high number - causing idle timing to go way negative and make the car run like dookey. Thing is reflash it and it goes back to idling and acting normal??? I never really mess with MAF mode on higher power boosted cars never ran into this before. Run10 is a pull in SD where you can see idle tps returns to much lower value and idle control timing acts normal after pull
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Jul 2012
    Florida
    1,472
    Your injector duty at 6000rpm is 108% on run22. Since the injectors cannot flow more than 100%, that could be a problem.
    2013 Silverado 5.3, 6L80k 8.8
    Baltimore, Md
    1,208
    These don't do anything other than go lean when dutycycle gets up there, and this was still controllable air fuel
