Results 1 to 3 of 3
Thread: 411 swap stock trans no lock up TCC
    Aug 2019
    Greenville, MI
    23
    0411 first read tune.hpt
    0411 first read tune shift firm_rpm drop.hpt
    First is the tune from pcmtuner.com which didn't lock up then. The tune had horrible slippage so the retune firmed up the shifting. Still no lockup. I read the repin form about the transmission wiring at the top of the page. Double checked that it was correct. Shifting from 1-2 is good, 2-3 is good, 3-4 it will not at WOT unless I let up a bit. Then it shifts. But doesn't even try to lockup the converter.
    I'm lost if you didn't know haha!
    Thanks everyone in advance.
    Everything is stock from factory, just did the 411 swap for tuning ease.
    Aug 2019
    Cleveland, TN
    87
    brake light switch out of adjustment will keep converter from coming on. WOT shift points should match 100% numbers in part throttle shift. bluecat trans table generator works really good for setting up tables. may want to check it out.
    Aug 2018
    Monroeville PA
    49
    If it would help,look at my post in GM V8 Tuning - Engine, Gas (Gen 3) "when I put it in reverse" mine is set up to apply at 35mph in 4th. I can even post the original tune where it locked in 2nd gear and stayed locked,even at WOT.My present trans tune is set up for when I run at the track,shifts kinda hard.
