I ran at the track last weekend and dataloged RPM, MAF, TPS%, Force Motor
Current and Last Shift Time and I was surprised to see that each shift was
0.5 sec long even though my entire Desired Shift Time table was set to 0.2
I also noticed that before the trans actually shifted the FM current started to
change to the shift value while the RPMs were still increasing. I also noticed
in this same area that the MAF numbers were decreasing even though the
RPMs were increasing and the TPS was 100% ? What should the transmission
and TCC be doing during a WOT shift ? Is there a tuning method that makes
the transmission shift faster and more precise ?
Thanks >>>>> INTHERED
P.S. >>> I have heard of people setting the shift MPHs to zero and using
only the RPM settings would this technique be better for racing ?
