Results 1 to 2 of 2
Thread: Siemens Delka 80lb Injector Data for P04?
    Has anyone used 80lb injectors on a p04 computer and could send me their tune? I have been trying to make sense of converting values from an ls1 style computer into the p04 but the tables arent even close to matching and I have not had any success.
    2000 Bonneville ssei computer. E85 smaller pulley zzp cam in a nissan 240sx (rwd).
    Dec 2008
    Nevada
    4,339
    as long as you can run 80 lb/hr in the flow rate table without limitation then you should be ok. These should be close to sd 80's on a vacuum referenced regulator. its how the 2000 bonneville file in the repository is setup so i duplicated it with sd 80 data i had.
