Quote Originally Posted by samtuning View Post
update on low timing target..i am feeling there is sort of limiter or tcu retard.
Did you ever get timing sorted? Having a similar issue and found this thread. I see your finalA changes but what did you end up with? do you mind putting up what you ended up going with? it would be awesome to see the comparison between your two files so i could try and understand the process of elimination your brain used to get it figured.
